Techron / Gumout : Use Only Just Before Oil Change ?
PNW
I get it that ideally you would want to run a tank of gas containing Techron / Gumout right before you change your oil - but what if that is not possible and you need to change the oil with 3/4th to 1/2 a tank of gas containing the fuel system cleaner in it ? In a well maintained engine , is there any problem with changing the oil while you still have a tank of gas left containing a bottle of Techron / Gumout in it ? In my case I used Gumout Complete fuel system cleaner .
The “use a fuel system cleaner in the last tank of gas before your next oil change” is found every where here and elsewhere . The logic is that any deposits removed by the fuel system cleaner will land in the oil which will be changed soon when the gas tank + fuel system cleaner reaches down to 1/4 gas tank… *My question is in a well maintained engine , often using top tier gas the likelyhood of fouling up oil with a high amount deposits SHOULD be limited ?
And where did this notion originate?
Is it pure myth or from a reasonable body of evidence?
seriously
Back in the days when Terry Dyson was on this forum, he recommended an oil change following my use of BG-44K.
Note: Dyson Analysis was a fixture in the oil analysis business for years
seriously
Chevron used to make such recommendations right on the label, as well as warnings about excessive dosage.
Gasoline is already a pretty powerful solvent, but not enough to dissolve fuel deposits. The addition of another solvent increases the risk of oil contamination.
In practice, disregarding the recommended guidelines isn't going to lead to the end of the world. But this is purportedly a place where people are inclined to follow the best practices, no? (aside from brake fluid, that is)
