Taurus SHO ignition problems
Hello, in a time cruch but I'll get yall up to speed. Fixing a 1994 Taurus SHO MTX, car uses a Low Data Rate ODB-I compliant EEC-IV computer with a waste-spark distributorless ignition. And she don't run. Sometimes get some detonation while trying to crank, sometimes at WOT I can get her going (like trash) for a few moments.
The architecture: car uses an electronic DIS module grounded thru the beautiful aluminum intake. Receives input from a crankshaft and single camshaft position sensors, I think they are HAL effect, at least one of them is. Sends signal directly to the coil pack. There is also something called a SPOUT connector that when disconnected, disables PCM input to control spark advance and dwell. without it, spark defaults to 10 degrees advance.
So here's where I'm at:
CKP is about a year old, Tach works
CPS is new, previous oil-soaked but still working sensor made no difference.
DIS module was triple-tested on a machine, verified ~.3ohm ground to chassis.
PCM reman installed ~2 years ago, show no other oddities in operation.
CCRM: ?. Fuel pump and fan work normal. Still no A/C tho.
COIL worked last year.
WIRES: Havn't done a test yet but I have a new set in storage
PLUGS: New Denso, forget the number but I think they are the actual OEM. The front three I pulled this morning were wet with fuel and mildly but evenly sooty, wiped right off. Gapped at .042, tested continuity from tip to tip, hard to get a steady probe my voltmeter showed between 3.7 and 4.8 kOhm.
One thing I've learned from watching many South Main Auto and Pine Hollow Auto Diagnostics is that you better use OEM electronic parts from OE sources, or you're asking for trouble. Any one of those sensors/components you've replaced could be suspect if they are not genuine OE quality from the OE source. I've seen countless videos of these guys troubleshooting electrical faults only to find that the aftermarket sensors were the core problem.
When I repair stuff, I have no problem using hard parts (shocks, brakes, hoses, belts, calibers, yada yada yada) from 3rd party sources. But when it comes to electronic stuff, it's strictly OE for me. I realize that makes it hard at times, because the OE parts may be out of production; then you're at the whim of China-based 3rd party junk.
Yeah...can't buy *jack* for this motor. Some parts you can't even get new aftermarket lol. There is like, one specialty SHO supplier and his stuff looks just like my CarQuest junk, but he's at least well respected by the SHO community so I'll still trust his selection first (even at double the cost). Best I could do is OE plugs.
Got one, wayyy too dim, and it's not gonna fit the coil-to-wire connections.
Take a piece of ordinary low-voltage wire, hold one end on ground the other end about 1/2 inch from the coil tower, and crank. Should be strong blue sparks.
The other side of the waste-spark coil should remain connected to its wire and plug while you do this. In other words disconnect one spark wire at a time to test.
If you have spark check that the wires are in proper order each post going to the correct plug. Use a timing light on wire 1 to see that it is firing in time with the crank.
Well, doing a sanity/resistance check on the new wires I got, a few were as high as 55kOhm. It's maybe 3 foot at best. That's...not good, right?
No spark on any of the coils
Seems to be no output from the DIS to the coil, at least not according to my incandescent test probe. I had the DIS tested on a bench machine tho and it passed. Now what do I look for?
I don't know much about this system other than looking at a diagram.
Disconnect the yellow wire SPOUT connector so the ICM is timing sparks internally and not depending on the PCM. The nearby red wire SPOUT only sets the PCM in a test mode.
Check for power to the module and coils on the red/green wire both with key on and while cranking. All the coil wires should also have 12 volts. The red/blue wire at the module should go live while cranking.
Hall sensors work at any rpm so you should be able to test output of the crank sensor (gray wire at the module) with a voltmeter and turning the crankshaft with a wrench while the key is on. Disconnect the coil first to prevent any possibility of inadvertent firing. There will be 3 pulses per revolution. The cam sensor (light blue wire) could also be tested this way but it should always make sparks (not necesarily properly timed) even with a bad cam sensor.
Erm...was checking that with the voltmeter and got nothing, so I checked the power. Long story short...if I'm getting continutiy between positive and ground, that's bad. right? Like, red probe on positive, black probe on, lets say, alternator? random bolt? "BEEEEP"
I
Uh, no, there is a ground cable that connects the negative post of the battery to the engine and the frame so you are completing a circuit when you measure between the positive post and the block.
Check volts with the key on. Put the black lead of the voltmeter on battery minus for these tests.
I would think the sensor voltages would go from 0 to 12 as the crank turns.
So...there's a metal disc of sorts that goes on the crankshaft, has three 'veins' for the sensor to pickup.
What would cause one of those to bend and chew up the sensor? It's been sealed behind a timing cover this whole time, and there's no debris in there
Make sure the belt is in time as it has jumped a tooth many cars will loose spark or injector pulse if timing is not happy
