Originally Posted By: QuOk
Originally Posted By: spasm3
Replace coolant sensor in head, also check/clean ignition coil mounting area for corrosion..
Thats posted as my quote , but its not mine.
The coolant temp sensor is a good suggestion, though the op states he has the brass ETCS. A 97 model never came with a brass one, so its been replaced at least once. In this case i think with out any misfire, that the coils are ok.
Again, I'd do a compression check to see what it is, and if it indicates a jumped timing chain. If all 4 cylinders are about the same but low, that would be an indication. Especially if they don't go up much after a recheck with a tablespoon of oil added to each cylinder.
