Tapmatic cutting wax for tool box slides?
JHZR2
Staff member
New Jersey
I have a few drawers out in my new to me Kennedy box. I figured I’d clean and lube them. The good news is they’re very clean and dry, and slide smooth.
The bad news is I don’t know what to use. I have silicone oil and motor oil. My understanding is that paraffin may be the right product to use, which I’m not sure that I have. I do have tapmatic cutting fluid that is like a wax until you touch it. It’s Octadecanol as I recall.
Thoughts on using this versus anything else? I’d rather not buy another product.
This is also in consideration along side just a tiny squirt of atf.
Thanks!
something that doesnt collect dirt..
like this for 2.39$
dont know enough about that cutting fluid to say.
I was told to use white lithium grease, but Accuride doesn’t specify:
My new slides from Snap-On had very little grease on them.
That looks like it’s for ball bearing slides
Accuride slides come with a clear (actually translucent) grease of some kind. I've always assumed Superlube, but could be totally wrong.
I do know that Superlube is a very low viscosity grease and seems to be well suited for a series of ball bearings that are in a straight line.
I used Door Ease on my new to Mac toolbox that had friction slides. Seems to be working well so far in a non climate controlled garage.
Don't overthink it . Most any lube , used SPARINGLY will suffice .
Sure. But I’ve heard oils and heard wax. Oils and greases can catch dirt that waxes may not. The garage this will be in does get somewhat dusty for whatever reason (the doors aren’t tightly sealed at the bottom, will fix that). So it would be nice to not attract dirt.
like this for 2.39$
This stuff is pretty hard to get onto the working surfaces.
View attachment 137630View attachment 137631
Thanks!
cuttung wax is no good. Ballistol would be good
