Tapered Pad Wear
CA
16 E350, 147K.
This set of pads has 53K. The originals went 93k+. Both sets of pads were Genuine MB.
This is an ATE style caliper. The pads were fitting correctly in the caliper (not difficult at all to remove), guide pins were smooth and piston retracted smoothly.
Any ideas?
I think I see the problem. It may have been free once the caliper was removed but in operation it looks like it may have been hanging.
I think you are correct. I will give the bracket a good cleaning and lube the ears. Previously, I had used 3M copper anti-seize brake lube. Perhaps that was inadequate.
That area is hard on lube. High temperature and pad dust.
I prefer to have synthetic high temp grease there, and new stainless steel or brass hardware on bracket (if the design has those).
PS: That's from my 2000 Sonata. Brembos came with their own grease and SS hardware.
polypropylene glycol monobutyl ether…
News to me, thanks for sharing. When I have used it, the product reminded me of a somewhat thick silicone paste with moly. But I guess it is something else.
Is there any difference in the applications for the CRC Synthetic Brake Caliper Grease and the CRC Silaramic Brake System Grease? I’ve been using the Silaramic.
https://www.crcindustries.com/products/silaramic-174-brake-system-grease-5-wt-oz-05361.html
In my limited experience, the silaramic product was very short lived once exposed to the elements. It is probably fine for lubricating OE style two-piece shims. I think I gave the tube to @nthach.
Unfortunately, this style of caliper does not use stainless steel shims in that area.
After further review, I used 3M's copper brake lube on the contact points of the caliper bracket. It appears that several brake pad manufacturers and vehicle OEM's have stated to not use copper based lube. Is it possible that the copper lube that I previously used, resulted in corrosion on the surface?
Well, if New Flyer trusts Plastilube on a bus that weighs up to 28 tons, it’s good enough for me to use it on non-rubber parts.
Yes, I do have that tube of Silaramic. I’ve used it on a drum brake job I did a while ago. The Prius is starting to be a little “chatty” lately - I’m going to try it out on that. Currently, I’m using Permatex’s new orange silicone lube.
AC Delco 10-4019 brake grease on the pad contact points and the slide pins. Looks like a pad or guide pin isnt sliding freely. The delco silicone is the best brake grease I have ever used and I have used almost all of them over the last 20 years. Its the same grease that is included in a genuine gm pad set
Yeah, I think the 3M copper anti seize left the surface a bit gummy. The wear on the bracket probably did not help.
But it is all better now. I cleaned the bracket well, lubed the contact areas with Permatex purple and buttoned it back up. Rotors were still smooth and well above minimum thickness so they were reused
