TAMA vs OE Honda Thermostat
Warner Robins, GA
Need to do some coolant system work on my 2008 Honda CRV and I'll make a post about that later, but wanted to make a specific post about the Tama thermostat I ordered from Rockauto. On RA it claims to be the actual OE part which intrigued me, and upon arrival I believe that to be true. Made in Japan and had a little sticker covering where (I assume) the Honda badging was ground off.. Tama was $21 on rockauto vs $70 from Honda.
Here's a link with good pictures of the OE thermostat:
https://la-parts.com/products/genui...n43KcQFmqcPCbGWvMJQd6fw0cvSDyMaA_2BrYEULj0pQ8
depends on the thermostat if it was a junky MotoRad or a 70$ oe I'd vote with my wallet for doing the job once.
In this case it looks like the TAMA is a good option
Thermostats generally are easy to replace. I would take my chances.
  • Like
Reactions: wlk
View attachment 337568View attachment 337569View attachment 337570
Thanks- very helpful
I would go with the $21 stat. I would never pay $70 for a thermostat.
I think I mentioned that a cheap Stant radiator cap was stuck closed and ended up causing air pocket in my cooling system, then leads to a warped head and leaking head gasket.
I would think the $21 Tama is good stuff as that stat is obviously an OEM with label grind off. After that head gasket, I would no longer trust a retail only brand who doesn't do OEM business, especially the ones owns by private equity.
Weak links in the chain of expensive repairs.....think- if only I had sprung for a better part. Things like this I may not buy OEM but I strive to buy the product that the OEM subs the contracts to or an equivalent. no skimping.
