Background: https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/5098716/lapping-valves-vs-machining
I recently repaired a 2006 Accord V6 with 149K that jumped time while idling. This is an interference engine which means the valves will collide with the pistons if the timing belt breaks (or if the engine goes out of time for another reason). No piston damage occurred.
Just wanted to share how much it can cost to repair one if this situation happens.
The book time to remove both cylinder heads is 9 hours.
In comparison, a used engine with 67k miles was $1200. The cost of the necessary gaskets, a new timing belt kit, hoses, coolant, oil, etc is about $550. So in this situation the parts cost was comparable but the labor time to swap an engine would have been slightly higher. We decided to repair the engine since the engine was working fine before this happened, but it may not always make the most financial sense.
Point is, it is possible to repair a Honda V6 engine if it jumps time, but try to avoid the situation if you can.
Photos of the job and of the bent valves can be found below.
Code
Brand Quantity Part Number Description List Price Total Genuine Honda 2 12251-RCA-A01 Cylinder Head Gasket 56.42 112.84 12 12210-PZ1-004 Valve Stem Seal - Intake 2.15 25.80 12 12211-PZ1-004 Valve Stem Seal - Exhaust 2.15 25.80 5 14721-P8E-A00 Valve, Exhaust 29.13 145.65 4 14711-P8E-A00 Valve, Intake 18.88 75.52 2 91213-RKG-003 Camshaft Oil Seal 8.73 17.46 1 91212-5MR-A01 Crankshaft Oil Seal 9.12 9.12 6 91301-PLC-000 Fuel Injector O-Ring (upper) 2.77 16.62 6 91302-PNA-003 Fuel Injector O-Ring (lower) 2.15 12.90 1 91301-P2F-A01 Fuel Rail O-Ring 2.82 2.82 1 17065-RCA-A01 Lower Intake Manifold Gasket - Rear 19.7 19.70 1 17055-RCA-A01 Lower Intake Manifold Gasket - Front 19.7 19.70 1 18715-PB2-000 EGR Valve Gasket 10.37 10.37 2 91314-PH7-003 Coolant Pipe O-Ring 3.1 6.20 1 19411-P8A-A03 Water Passage Gasket, Front 5.3 5.30 1 19412-P8A-A02 Water Passage Gasket, Rear 2.6 2.60 1 19421-RCA-A60 Hose A, Warmer (ATF) - Split during removal 3.4 3.40 1 19501-RCA-A00 Upper Radiator Hose 21.95 21.95 1 19502-RCA-A00 Lower Radiator Hose 28.73 28.73 4 19511-PH7-003 Radiator Hose Clamp 7.95 31.80 2 18115-RCA-A01 Gasket, Exhaust Chamber 6.17 12.34 2 12341-RCA-A01 Valve Cover Gasket 10.5 21.00 1 90704-RCA-A00 Crankshaft Sprocket Key 5.95 5.95 1 15400-PLM-A02 Oil Filter 7.3 7.30 1 19301-P8E-A10 Thermostat Assembly 64.33 64.33 Fel-Pro 2 ES71329-1 Cylinder Head Bolt Set 23.79 47.58 1 MS96410 Upper Intake Manifold Gasket Set 19.49 19.49 CCI MFG 2 128524/168 Super Extended Life Coolant - Blue 11.66 23.32 Mobil 1 1 Mobil 1 5W-20 Full Synthetic, 5-qt. 22.88 22.88 NGK 6 6994 IZFR6K11 Laser Iridium Spark Plug 8.20 49.20 Aisin 1 TKH002 Timing Belt Kit w/WP and Hyd Tensioner 178.78 178.78 Bando 1 6PK2135 Serpentine Drive Belt 20.55 20.55 Subtotal 1067.00 Tax 93.36 Machine Shop Charge (3-angle cut valve job and resurface heads) 540.00 Grand Total 1700.36
