A friend of mine has a 2005 Tacoma 4x4. I helped him do a brake job and when we checked the rear breakes we found the rear axle seals leaking. He ended up taking to a shop to have it repaired.
When it came back, his truck has a low pedal, the brake warning light and ABS light was on. The shop told him that the ABS sensor on one rear wheel had failed and they will replace it for the cost of the part only. He complained about the low pedal and warning light stating the might need to rebleed the brakes. They told him they would adjust the brakes to get rid of the low pedal and that the warning light was on because of the ABS sensor failure not air in the lines.
I know that you have to remove the rear wheel cylinders in these trucks to do the axle seal job, so they would have had to bleed the brakes. But their story doesn't add up to me. I have never heard of the brake warning light coming on for ABS problems? And it seems pretty coincidental that the ABS sensor failed at the same time the axle seals were replaced.
Any opinions?
Any opinions?
