Okay, so I have a nice 0-6000 mini tach by AutoGauge that I want to install in my son's Chevy S-10 Pickup. I am told to either get the wire off the coil (coil pack?) or from behind the instrument cluster. I would go to the coil because usually that is easy to access, but this one is impossible. I don't know how GM puts a 4.3 V6 in these trucks because the 2.2 4-banger is already packed in very tight so you can't get at much. If I knew the right wire I might get one of those cheezy snap clip connectors on it, but that is sure to corrode and stop working after several years. No way to solder it in that location, can barely get one hand up to the coil from below and looks worse going from above.
Pulling out the gauge cluster seems like a big hassle too. I wonder if I can get a wire bundle going through the firewall and pick out the correct wire. Alternately, is there an induction pickup that just clamps onto a spark plug wire, like some of the old timing lights used to do?
