T6 15w40 - what's to cold?
Originally Posted by BrianF
Don't think twice. Run the 15w40. Already said, many people I know run conventional 15w40 all year up here. When it gets too cold, they use a block heater.
Only thing is my block heater has a recall on it that I still haven't fixed yet so I probably won't be using a block heater
I guess you should have got your recall done or changed the oil to 5W-40 if you're that worried about it?
The 15w40 should be fine.
My owner's manual for my lml, if I remember correctly, states to not plug it in until 0f or colder. I'm assuming yours is similar or even better. An anti-gel, on the other hand, is a must in cold temperatures. I will not be stuck with gelled fuel again.
always wondered why we don't see this here … this one from the UK
Yeah same for mine 0F
Because that grade is like "molasses" to you over the pond
I wonder what that makes the 15w40 generally used here?
15w40 was developed as a "diesel-specific" grade back in the 1970's after 10w40 oils were shown to be shearing out of grade, providing insufficient protection for diesel engines.
