I was a little apprehensive to say the least at the thought of taking my 2002 Explorer to Jiffy-Lube for anything. I have heard the horror stories like everyone else. I needed to have the tranny fluid exchanged (at 45,000 miles for the first time) and the dealer wanted $169.99 for a flush, plus some special cleaner. Too much, no thank you. Probably would have been $149.99 without the cleaner fluid. Still a tidy some of greenbacks. Jiffy Lube was only $89.99, so why not I thought. There was no wait when I pulled up, so that was a plus. The fun part was watching the technicians scramble to find the tranny dip stick, because my explorer does not have one. Then I watched as they tried to figure out which fittings to use... ect. All told it took them about 35 minutes to complete the transfer. As I drove away, my thoughts turned to "oh no...what have I done to my explorer?" But all is well now and I would not hesitate to use them again for that service, BUT only that service.
Just thought I would share my experience with you all in case there is someone out there that has been thinking about it, but has not built up the nerve to go to a Jiffy Lube for the T-Tech tranny service. Probably the same machine that the Ford dealer was going to use. I guess the only real difference is that Jiffy Lube uses the multi-purpose Pennzoil fluid that is Mercon V rated and the dealer would have used MotorCraft Mercon V. Probably not worth the price difference...
