Originally Posted By: Astro14
It would really help if we knew "why" you want a T-IV? What are you putting it in that requires a T-IV? Some AW, I suspect...
I am strict on the use of a JWS-3309 fluid in my Volvos, they require it and the AW55-50SN trans is known for "issues", but I have none of those issues because I do a cooler line flush every 30K with genuine Toyota T-IV (which I buy at my local dealer and which meets JWS-3309). Is it "medium" or "good" or "really, super, kind of good dino/synthetic"...I really don't care...
It meets spec, it works, the trans is up to 163,000 miles (in the XC, 138,000 in the T5) with no issues while I hear the crying over failed transmissions from all the other XC owners on the forum I belong to...
+1 I use only T-IV/JWS-3309 in the U151E on my '06 Sienna. No issues. It meets spec, and it does the job. I refresh it with annual drain and fills. If it came with a fluid from the factory known to cause issues, then I would consider something else, but it is doing the job well, so I have no reason to look at another fluid.
