Originally Posted By: Gokhan
Originally Posted By: BenBenz
I changed the oil in my daughter’s Kia Amanti and used full synthetic (Mobil 1, 5W30) for the first time. This was back in July, 4,000 miles ago. A few days ago she told me the engine was making a noise, like a valve clatter. I checked the oil and it was about a quart low, so I added a quart, but the noise continued, to a lesser degree, so I took it to the repair shop. They guy calls me later in the day and said the oil hadn’t been changed in 10,000 miles (he was going by the sticker from the last oil change I paid for before I did it myself) and said the oil was "nasty." I explained that I had changed it recently and he seemed at a loss. I found on the Mobil 1 website that sometimes when you use synthetic for the first time it cleans out so much gunk that you should change it again after a couple of thousand miles. My
mechanic seemed skeptical of this explanation. He changed the oil again and the noise stopped. Has anybody experienced this situation? All my other cars have always used synthetic, so I’ve never seen this when I change the oil.
Synthetics result in less engine friction, which results in more horsepower and more fuel economy.
Less engine friction and more horsepower will change the way the engine sounds. It's nothing to worry about. Your engine will last more with synthetics, not less.
The long story short, synthetics are always better than dino, except in engines that are designed to burn oil (such as rotary engines). They will not only increase the performance but the durability as well.
PS: As you and others mentioned, it's true that Mobil 1 and other good synthetics in general clean like crazy, and it may have clogged the oil filter since you have been using dino before, which tends to leave much more deposits. Mobil 1 oil filters don't have much dirt-holding capacity -- because they are pretty small -- so, this could have happened.
Less friction with synthetics,engine will last longer with synthetics.
This entire comment is perpetuating more myths than facts.
Show me an engine,that was serviced properly that lasted longer using syn than conventional.
The additives reduce friction,not the basestock.
Most of this comment is based in fairy tale land.
