Originally Posted By: KrisZ
Originally Posted By: boosted427notch
You may be correct,but which will show less wear? Extended drains are not a concern for me. I just think that if syn will cause less wear, buildup, and last longer if I need it to then whynot.
Use whatever you want, but stop spreading nonsense that even oil companies are not willing to tackle.
Mobil did a 1 million mile test on their synthetic oil and shoved how clean everything was, and that everything was within specs, BUT they never compared synth to dino, or even mentioned that the wear numbers were better on synthetic. They never did a similar test using their dino oil and synthetic side by side, just to show how much better synthetic supposedly is, how hard would that be? If synthetic truly produced such dramatic differences they would surely try to capitalize on it.
Lack of such a test is a clear indication that the differences between dino and synth are not that great if the OCI is kept per manufacturer recommendation. This is why knowledgeable members will always ask what OCIs will be run with synthetic and what application
Being a little hard on him dont you think? I know what I posted earlier is jmo, but hey, it`s working for me. So if he wants to go synthetic because he feels the motor will stay cleaner (which in the MZ motor, it probably will) let him use it. I also use my current stash of VWB,and GTX, but shorten the drain interval.
