Synthetic Oil Filter
I chatted with Fram teck support and they said that they do not make a filter for this motor.
Subject
Product Information
Show more
Chassity 09:38 a.m.
Hello. May I help you find the right FRAM filter?
ROGER BACON 09:39 a.m.
Do you make any oil filter for a 2021 GMC 2500 with a Duramax diesel engine?
Chassity 09:39 a.m.
One moment please, while I find the data on this.
https://www.fram.com/en/elasticsearch/index/display?Application=Car & Truck&Type=Any Type&Year=2021&Make=GMC&Model=Sierra 2500 HD&Engine=6.6L V8
PH10575
ROGER BACON 09:42 a.m.
That is for the gas engine
Read
Chassity 09:43 a.m.
I do apologize I misread your message we do not have one available for the diesel engine at this time.
Would anyone ever trust what this person says again?
Said he misread your message. If Fram doesn't show the filter in their look-up tool for your truck, then it most likely doesn't exist. That's all the Fram guy was doing - using the look-up tool.
The Wix filter for your truck has a higher bypass pressure than the PH2 and equivalents, it looks like as of now the newer duramax engines require an application specific filter.
After all that work and discussion, I have decided that the Mobil 1 @ 30m is not the one I want. I am going to continue to use the NAPA gold. Easy to get, not to expensive, 20 mic. rating and I do not go over 10,000 km. anyways. Thankyou everyone for all your help and advice. If the manufactures' could get their s**t together, and correct all the misinformation on their sites, this would have been a lot easier. Roger
