Synthetic oil change interval
Ormond Beach,FL
My son has a 2006 4 cylinder Camry and is only putting on 3-4K per year while in school. He uses synthetic. Would you base oil change on mileage or time, and how many miles/how long an interval?
From what I've been told, It really depends on the case. If it is all highway miles, he should be fine doing a 1 year oci, but in my case, 6k a year would be pushing it since I drive almost no highway miles, and all I do is <6mi trips
With mileage that low I would base it off of time. Some will say dump it at 1 year and some will say leave it in longer and get a used oil analysis done.
Is it mostly short trips?
If so, I'd probably do annual changes but switch to mineral oil. No point wasting money on synthetic.
If these are not short trips, and you want to stick with synthetic, you might get away with changing it every 2 years.
Id go once a year and not worry about it. Just run M1. Pull a used oil analysis to prove it to yourself if concerned...
Most European makers have switched to a 2 year recommendation, from the previous 'at least once a year'.
The change was driven by regulations, but it's more than changing the text in the owners manual. Long-Life oils have stronger and longer lasting additive packages.
Another element of extended change intervals is the lubrication system. BMW I6 and V8 engines have big filters and oil sumps that hold 7+ quarts. With twice the oil and 3x the filter area, an 15K-18K mile change interval looks reasonable.
At only 3K-4K miles per year, you do start to wonder if annual changes with conventional makes more sense than mileage based changes using synthetic oil.
LOL! If it's the 2AZ-FE engine that my wifey's 04 LE has and we've been doing 8k OCI for the past 4 yrs, then well, you are "blessed" by putting syn oil in such application.
my wifey's camry now has over 142k on the odo and no oil consumption issues, no leaks, nada. Still passing the local emissions testing every 2 years (mandatory) while using either Pennzoil Conventional or Quaker State Conventional 5W30.
Maybe I'm cheep but I don't see the benefits of using syn on this engine.
Q.
Depends on the use of the car. If all of those miles are long trips, say coming home for awhile, or going to the next town over or something along those lines, then once a year would be fine on the synthetic. My grandma puts about 5-6k miles a year on her car, but it's all highway when she drives, so I run synthetic in it and change it once a year.
Now if those miles are short trips, I'd run any name brand conventional and change it everything 6 months. Pennzoil conventional, Valvoline conventional, and Mobil Super 5000 are my go tos for things like that.
Exactly my thoughts^.
I would've thought the opposite is true. I thought starting a cold engine was the worst thing for an engine and where synthetics really provide the greatest benefit. So lots of short trips around town it would be best to use synthetic. On the other hand long highway trips are relatively easy on an engine, fewer cold starts per year relatively speaking, so no need to go anything more than a decent conventional oil.
+1
Originally Posted By: dave1251
Why jjcom is making that recommendation is due to short trips and not warming up your engine leads to fuel dilution.
Ahh, thanks. Still, from what I've read synthetic is better for starting a cold engine. Several cold starts a day every day, might want to run synthetic and run a used oil analysis after 6 months to see if fuel dilution is even a problem with that car.
