This winter I'm going to be driving my newly purchased $300 1987 Chevy Caprice with the factory 307 Oldsmobile roller cam motor, with 4bbl carb. It has around 150k on it. Temps will go down to -25C. Car has a block heater but I don't know if it works and I probably won't bother to plug it in most times anyways, my previous 86 Caprice never had a problem starting without a block heater. I want the car to start no problem, but thats not usually an issue with these if the carb is set up right, I do have a pretty bad oil leak at the valve cover gaskets and who knows where else, but I've only driven it about 2000k since I got and changed the oil so I don't really know if it uses any. I'm thinking about esso xd3 0w40. What other oils should I consider?
