Has your Century had the intake manifold gasket replaced....the OE gasket were known to fail. I would do a UOA and check for coolantMy Daily is a 2000 Buick Century with the 3.1. It had 24k on it when I inherited it 5 years ago and has 108k on it now. It gets 5w30 High Mileage SynBlend in different flavors. Valvoline Maxlife, Castrol GTX, Providence (rural king). OCI’s are 5k. Engine doesn’t use any amount to speak of.
Like was mentioned before any SP/SQ is far better than what it would’ve gotten when new. Pick one and enjoy.
and if present have the gasket replaced with an upgraded gasket.
I also had a 2002 Century and ran just about every type of oil (dino, blend, syn.) without issues. It was a great car and regularly got well over 30 mpg on long trips (32 to 34 being normal). I did have to have the intake manifold gasket done but IIRC GM sent me a check for the cost. I would change the ATF every 30K to keep that 4T65 running well.I had an 02’ Buick century with the 3.1 in it and I only ran Valvoline MaxLife in it and it was a great oil with zero issues.
