Hey Guys and Gals..
Will be lookin into doing a full flush ( via transmission pump method fill/run/fill etc. )
My car is a 97 SSEI with 4T65E-HD and was told not to run synthetic cause there's too much slippage and shorten the life more then regular transmission fluid.
I was also thinkin of adding in Lucas transmission fix as precaution but apparently it's not the best and the other option ( can't remember the name of that brand now ) I have never seen in Canada..
My question is.. if my mechanic and other bonneville owners are sayin not to run synthetic. Should I not?
It also calls for ATF IIE. Is there a better kind I can use without going synthetic?
