As some of you may know, I auto-x my '02 4AT accord on a bi-monthly basis, and will probably bracket (drag) race it at least 6 times a year.
I had a new transmission installed earlier this month, which was filled with Honda ATF-Z1. Last night I hit the 1k mark, so I reinstalled my trans cooler, along with a Derale 13011 180*F thermostat (bypasses the cooler until it reaches roughly 170-180). I also did a drain+refill with Amsoil ATF, making it 43% Amsoil and 57% 1k-old Z1.
Tonight I hope to install a Wix 24764 remote oil filter mount, along with a wix 51622 transmission filter (thanks fleetfilter!).
I'm guesstimating that I'll have an increased fluid capacity of aroun 7-7.5 quarts, and at least 50% amsoil in there.
I was planning on waiting until I hit the 10k mark before doing another drain+refill as usual, and replacing the filter, but would it be worthwhile to do it for the next two 5k intervals to quickly increase the amount of Amsoil, then go back to 10K intervals?
Perhaps I should be doing the 3x drain+refills of amsoil right now? The remaining Z1 in there is in the best shape it could ever be, but in my past experience, it wasn't in great shape if left in service for an extended period (10k drain+refills wasn't enough to keep the Z1 in decent shape).
Just not sure if I should still keep a high percentage of Z1 in there if I am to resume racing the car...
