Switching from 0w-20 to 0w-30 experience
We agree on something!
But I always choose less wear regardless.
That is typically the case with people when you start to listen to the other person. I don’t dispute your experience or knowledge.
You guys all beat me up about filters but the issue is not that I think you are wrong (I agree on the viscosity and filtration points - I am not ignorant) but that I have had some difficulty warranty experiences I would not want to repeat. Others have too. It’s BS I agree but avoidable aggravation. That’s really all. The 4Runner is on 5w30, and has been a while, since I no longer need to deal with the Toyota jockeys with golf shirts. The Ram has a lot of toys so it is under extended warranty with the downside I still have to deal with the dealer for the occasional warranty issue (back glass; wheel speed sensor).
Have a good day.
  • Like
Reactions: GW.
based on experience with mine I want to see what the frame rails and suspension attachment points look like, particularly if the vehicle “lives” anywhere where it snows.
He shows the frame extensively in the video. It looks pristine. I think he’s based in Arizona.
Interestingly he replaced the engine and didn’t just do heads.
  • Like
Reactions: RBT
Great example of this engine dying an early death. Easily could have gone 400-500k with better oil and shorter changes and in general better care like more frequent air filter changes and using Top Tier fuel. Penny wise and pound foolish here.
Wild he put all that money into it with aftermarket parts and did so much work himself but couldn't be bothered to do his own oil changes at 5k miles or use AMSOIL/HPL at 10k if he was committed to long drain intervals.
Do you really think air filter changes and fuel with more additives (assuming this is a port injected engine) would matter?
Since he burnt an intake valve, yes I do. He reported he neglected the air filter changes and didn’t clean his K&N filter as well. Lack of maintenance.
I'm still dubious either of those would CAUSE a single burnt valve ... sooo many other potential causes.
