I'm currently installing s new motor in my sidekick, while I had the motor out I pulled the torque converter and drained it. I also drained the transmission overnight too. The filter in it has 3-4k miles with the fluid that just got drained out.
My first question pertains to what I should refill with the transmission with. Its an 03-72le Aisin unit.
It has 200k miles on it. No metal in the pan or on the magnets at last filter.change. has a built in trans cooker in the lower radiator. The original fill was Dex 2.
My second question: ID love to run transmission fluid in the transfer case for some extra MPG...but it specs 75w90 yellow metals safe gear oil. When I got the vehicle at 160k...I drained the fluid and it was filled with some transmission fluid of some sort. Can anyone recommend anything?
