Hello everyone I'm back from vacation and I fix some off them that I could find.
Here's what I have install in past day;
Rear Oem Upper Control Arm both side
Rear lower control arm both side
Put on brand new spc toe bolt
Now the mods I only have on the car is;
Front/Rear Red Lion subframe bushing is been there
Front lower control arm red lion bushing is been there
Front/Rear Nismo sway bar (Not Endlink)
Rear racingline peformance endlink
My problem is when weather is warm like hot above 80 degrees then my rear right will make sound like squeaking,popping, or knocking when I'm turning right turn or while hitting bump or dip while going on the straight line. And for the front I'm hearing popping/knocking as soon I turn right/left both side or going straight line. Plus I haven't done alignment cause off noise I'm hearing.
I didnt wanna come back but I had to.
