Quick stroll through ebay see G96 is like $29 for 12oz!....what are people using now?, I'm almost out and need to restock.
Here is the link: https://www.amsoil.com/c/firearms-lubricants-cleaners/53/?zo=515729I use Amsoil gun lube but I will tell you that you absolutely don't need a specialized product.
That said Amsoil is lower cost!
While some gun lube is snake oil, some gun lube is, in fact, tailored to those radically different operating conditions.Motor oil. If it's good enough for $50,000 engines running 8,000 RPMs during races for millions of dollar purses, and relied on for operating temps sub zero to hundreds of degrees, it's good enough for a $1000 pistol or rifle. The motor oil industry spends billions of dollars on R&D. The gun oil industry is some dude in his garage mixing chemicals in a high school chemistry lab and beaker set.
Really depends on the cleaner. I've found Penray 4520 brake clean to be a comparatively cheap, safe and effective cleaner for many things. I've used it on everything from my guns (am careful not to get it on delicate wood finishes) to bike chains and sprockets and most things auto related with no concern of finish damage. Of course your mileage my vary... Try at your own risk. Others like O'Reilly branded brake cleaner (red/black/yellow can) is death to paints, rubber and some plastics. Wicked stuff! Great carb cleaner though. Funny story about the O'Reilly cleaner - my wife mistakenly grabbed it instead of the other stuff to clean the chain and cassette on her bike that I custom built/painted... Ended up blitzing the clear coat and paint right off of it on one of the chain stays!My new pistol S&W M&P 22 Compact has white lettering on the black aluminum slide and a plastic frame of some sort ...anyone think I might get away with a spray can of automotive parts cleaner? ...between that and the motor oil would solve the stupid $8 an ounce gun specific treatments.
After reading about another member's observations using non detergent 30 grade oil, I thought I'd give it a try. Just so happened we had an open quart at our shop, so I've got that in a 1oz bottle with a needle applicatorMotor oil for lube ftw
