Here is the deal. The way I see it you have more to lose then gain with SuperTech in this application. Supertech is going to be the most reudimentary transmission fluid you can buy. A transfer case has very limited capacity, high loading, combination of high and low rpms and no filter. I think I would spend a little extra and get Mobil 1, Redline,Amsoil, Schaffers or OEM Chrysler ATF+4 for this transfer case. These have robust additive packages with Redline being the beefiest. They all have outstanding oxidation resistance. Remember that most T/Cases hold 1.8-3 quarts of fluid. TO me the gigest thing is the fluid capacity. The cost for premium ATF will be low.
