Ok! I hd a bit of time so i went for a look. what metal purolator use for end cap! Flash binite stainless? Every other filter looked dirty by comparison.carquest filter are filty now i know why drivework seal with saran wrap the screwing end.but this aside.the st is a better value (nvm the model)its as clean as puroboss. Dont get me wrong look wise purolator inside and outside look pristine.Yes literally pristine.if look is important to you puroboss is the way to go. There probably will be an outside finish option i suspect.but i can say SuperTech ST-2016is THE FILTER TO GET
