Supertech good or bad?
I have a lifetime warranty starter that I can change in 15 minutes. The starter is the last thing I'm going to worry about.
quote:
Originally posted by Bret Chase:
snip.... I've also found that employing ClearFlood (holding throttle WOT while cranking) for about 5 secs further reduced the occurances of CSK in my truck to just about zero.
-Bret
Starter motors and seliniods are much more common repair parts than bearings. Most start up noise is just valve clatter. No sense adding wear to the the start system to avoid something that doesn't hurt.
Bret.....I've been using Purolator Premium Plus exclusivly. The price is right when on sale,($2.50 or less), the availability (Sears, PepBoys,Adv.Auto)is plentiful, and I think that I have had one PPP over the past couple of years that gave me some clatter upon start up. The PuroPremPlus seem to be held in high reguard here at BITOG.
quote:
From GAry; I personally don't think that you'll get 150% of the utility out of it over a ST ..but it is surely worth the added cost in the construction/design aspects of it.
Numbers are funny. 150% better sounds like a lot. However, we are talking about $1. Motorcrafts are definately worth the additinal $1. Betweeen the silicon ADBV and the more plentifull filter media. For $1 more they are a better bargain IMHO.
> Motorcrafts are a new re-issue to Wal*Mart stores.
Really? This is good news.
We're sure these are real Motorcraft and not a
re-badged FRAM, right?
quote:
Originally posted by bigwillie:
I've done a few searches but still have not been able to find out what you guys think of supertech oil filters. Are the supertechs decent filters? Or should I just stick to the wix and motorcraft I've been using? What is the supertech equivalent of an MC FL-1A filter? I have an 88 Bronco II 2.9L V6 with 45k.
Generally Super Tech filters do not fail in service, however, that is not to say they are "good" filters. There is very little info on the quality of the filtering job they do. You need a used oil analysis with a particle count to see how the filter does, there are few reported here.
In testing the Purolator Pure One and Mobil 1 filters generally produced better than average results. One BITOG member had a particle count done with a Mobil 1 filter and at something like 8,000 miles the oil was amazingly clean with very low particle counts.
ST oil filters - good or bad? Bad. (Use Autozone "Valuecraft" oil filters instead . . .
