Supercharged 4.6, oil recommendation?
Texas Hill Country
I have a 96 Tbird with a vortech supercharged 4.6L 99 Mustang GT motor, and ported heads, etc, etc.
The car is only in service in the hot summer, so cold weather starts is a non issue.
I am not going to run 5w30 or 5w20 in this motor.
The previous owner went with a Mobil 1 10w30, but I thought that was a little too thin.
I sent a sample to blackstone just now, and I changed the oil to 4 quarts of Mobil 1 10w30, and 1.5 quarts of Mobil 1 15w50.
The car is driven hard on the street and is a toy pretty much. It sees pretty much zero time on a track though.
Thanks,
Justin
I dont see any issues with the Mobil 1 10w30 weight , it'd be interesting to see the used oil analysis results, I bet they will be good results. Its a stable oil viscosity.
If you want to go thicker try the Mobil 1 Truck and SUV formula or the Mobil 1 Delvac to get a 40 weight.
I'd also recommend going with something like Redline's 5w-40 or 10w-40 weight, I'd like to see how that compares to your Mobil 1 sample. This oil is a lot more money than the Mobil 1 though, not sure if you'd see a whole lot of difference for the extra cost. Depends on how much you're willing to spend.
good luck , let us know the used oil analysis results when you get them.
