Super S pour point?
California
I know that pour point is considered on BITOG to be much less important than other numbers, but I notice that, for instance, Super S Multi-Flo 10w30 has a pour point of -17F, and the 10w-40, which I just bought some of, has a pour point of -11F. This compares to Kendall GT-1 Synthetic Blend 10w30 at -38F, and GT-1 conventional 10w-40 SN at -33F. Quaker State Advanced Durability 10w-40 SN shows a pour point of -33, and Valvoline conventional shows -33F as well.
Now, I realize that it's not going to hit -11F -24C in So Cal unless global warming really takes off
, but what do the great minds of BITOG think about this?
low grade base stock, little to no pp depressants? low vi?
I find little use in using no name brands when you can find major brand oil on the cheap frequently.
The Gulfpride AFE Semi-Synthetic 5w30 that my shop uses has a listed pour point of -49F. It is very similar to Brad Penn Superior Fuel Efficient 5w30 Synthetic Blend.
Pour point is a worthless spec these days. Look at mrV or CCS numbers. If your always above -10C PP doesn't really matter unless your car says it does.
I did the "freezer test" on some 10w-40, and I was surprised at how well it poured at 0F. Much thinner than, say, STP or LOS.
According to the PDS, it meets the -25 pumping requirements, so I guess even if it won't pour, it will pump.
Would be my guess, too. I'm assuming this a "cheap" brand oil. They have to cut corners somewhere to keep the price low, like using little to no pp depressants or vi improvers.
edit: The info could also be inaccurate or out of date. Who knows when the pds was last updated, or if whomever wrote it bothered to do a "full" update or just change a couple numbers?
Same here.
Let me clarify. This is a "less expensive" oil, but it's SN, and GF-5 in the appropriate grades. When PQIA looked at the SM 10w30, everything looked fine, and the low temp pumpability number was pretty good.
Pour Point became much less important to the site about the time that the majors started using GrIII a lot...about the same time as "it's not the ingredients, it's the total package" became the mantra justifying paying GrIV prices for GrIII.
