Originally Posted By: gathermewool
Originally Posted By: ARCOgraphite
Originally Posted By: Dallas69
No need to imo
After your engine gets up to operating temp they are both 30wt
There are differing shear stabilities depending on the service category within any multi-grade. AN ACEA A3/B3/4 5w30 will have a significantly higher HTHS than an ILSAC GF-5 PCMO.
The WT term is not correct.
Colloquially, xxWT is just fine, IMO. We all know that he means the 100C viscosity (KV) range, right?
OP, if you're worried about high-temp shearing, then follow ARCOgraphite's advice and choose a shouted oil (higher HTHS) instead of a lower-index multi-grade.
"stouter" Auto-correct to "shouted," for clarification
