Quote:
What tricks, if any, do you use to get more of the old oil out when you change it?
I've found with the CR-V that putting the front end up on jack stands and letting it drain for 3-4 hours gets all but about .5-.6 qt. of the total sump capacity out, and I'm looking for something comparable to do with the '93 Corolla. (The jack stand trick [rear end in this case] only helps minimally on it.)
Oil thinning products like the Amsoil engine flush help too, and I've done that once, but I don't want to use it very often, because I don't really need it to clean, and then I'm still faced with the problem of getting the remnants of the flush out, which even in a small amount can't be good to run for a whole OCI. (Amsoil guys, please do give your 2 cents on that issue. It seems like a reasonable concern, but maybe I'm wrong. How long does it take those remnants to evaporate?)
Is it advisable maybe to rig a portable tire filling tank up to a nozzle that fits over the oil fill hole, to blow the rest of the oil down to the drain hole? Would that have any effect at all, or maybe cause some kind of damage by blowing contaminants into the engine?
I suppose this is mostly academic, but, then, if there is a way to get more out without causing damage or too much inconvenience, why not do it?
