I have a ‘14 Silverado 1500 crew cab out of CT. Underbody is clean but cab corners showing a few small bubble under the factory rocker coating. I pulled the body plugs and there’s a 3-4” patch of rust where the sun roof drains are - still very solid but couple of pin holes which are causing bubbles.
The inside of rockers have a little bit of silt that has accumulated over 11 years. Is it worthwhile to flush the rockers before I treat? I’m not sure if I can get it 100% dry and with the existing rust it just seems like it’d do more harm than good to add extra moisture
I have wool wax, fluid film black, and a couple quarts of ATF. I’ve already sprayed some fluid film in the cab corners but waiting for nicer weather before I spray the whole rocker cavity.
Not sure what’s the best way to go at this. My last truck the rockers were completely gone so it wasn’t really an issue anymore.
