Suggest best car for frequent long trips
Originally Posted By: Y_K
I just got a two-tone 2004 LTC Ultimate with complete one-owner history, 37k on the clock, every option from the book for $14k. Put new bad black rims and Toyo Tourevo from Les Schwab and re-christened it into Doenitz. I already have one with 'Nimitz' on the plates. Easy on oil engine, excellent tranny and differential. But I am an old geezer, and I do this for both fun and living.
Y_K I really wish you did not post this cause its killing me I did not buy it...The was a awesome deal on a awesome car...You are sooooooooooo lucky to find that!!!!!!!!
I can see you are a very smart intelligent person with excellent taste!!!
Originally Posted By: ekpolk
Yeah, so what???? Those vehicles all weigh a half-ton less than a Camry hybrid
Vehicle weight is not as much of a factor in highway fuel economy as you might think.
Yes and no. At the end of the day, the laws of physics are immutable.
I suppose I should have been clearer. "Those vehicles" would of course, mean Metros, Civics, Aveos, and so forth. Not only are they much lighter than the Prius, they are much smaller as well. If I had a use for a call that small, that would be fine, but I don't. I want to have my cake and eat it to -- driving a larger car AND getting micro-car fuel economy.
The law I'm thinking of when I make that statement is the one that "an object in motion tends to remain in motion".
We discussed for a bit the other night and she doesn't really want a hybrid. She is kind of wanting a new Jetta TDI, I think. Over on Fred's (TDICLUB) where I also hang out, there seems to be a potential issue with the HPFP (High Pressure Fuel Pump) on the 09+ Volkswagen TDI's. They went to a CRD (Common Rail Diesel) fuel delivery design after dropping in 2006 (in north america) the Pumpe Duese they sold in Europe since 1999 and North America since 2004. The issue with the Pumpe Duese motors is/was a cam/follower wear issue cropping up on an above avg number of cars. But the cam/follower wear issue, if you have it, is a gradual process with known warning signs as wear increases with miles, as opposed to a "BAM!" catastrophic failure with little or no warning that the HPFP's seem to exhibit (i.e. strand you).
That only applies in a vacuum. In the real world, as it pertains to cars, there are opposing forces that act as limitations: friction between the tires and road surface, wind resistance, and gravity (as when climbing any kind of grade) all come readily to mind.
On any degree of grade, more weight means the engine has to work harder, meaning more energy consumption to attain the same speed as a lighter vehicle - all else being equal.
With wind (or even still air), a smaller car has a smaller frontal surface area that requires less less energy to push through (or overcome) the resistance at a given speed, again - all else being equal - favouring the smaller and presumably lighter car.
So the points made regarding the Prius versus cars like the Metro, etc, as the latter having natural fuel economy advantages do to their size and weight, are valid. Ultimately Newtonian physics prevail, but if you're going to cite it, then it doesn't mean anything when you leave out these other factors.
Now if you're talking space ships and interplanetary travel then yeah, you have a point. But we're not there yet.
-Spyder
If she is looking for a low maintenance car, then I'm sorry to say a VW Diesel probably isn't the brand. Will it likely go forever? Probably, but at what cost?... No I still stand by recommendation of a Focus, Fusion or Malibu.
This could be expected to be higher in a heavier vehicle and would be responsible for the majority of the fuel economy decrease that you would see from adding weight to a vehicle.
Quote:
wind resistance
Has very little to do with the weight of the vehicle.
Every uphill has a downhill on the other side.
Adding 1000lbs of load to a sedan doesn't increase it's frontal area.
What I said was, vehicle weight has less of an effect on highway fuel economy than you might think. I suppose I should have added "all else being equal".
Originally Posted By: ARCOgraphite
Hp does not matter to maintain speed on the highway. You are talking 60-80 MPH and at those speeds (2000-2500rpm) a 2+ litre 4 cyl is making about 60-70HP wide open and under 30HP at part throttle. It is "torque at rpm" that keeps a car going steady state on the open road and you are not spinning 6000 rpm!
I will say a 3400 lb car is not "blown all over the road". The Vic is only a few hundred pounds more. The GMQ LS (w/ dual exhaust, leather, handling package) I rented 2 year ago drove great. Tight, responsive and comfortable. LoneRanger's spouse will ne're go for that grandpa kinda car - guaranteed, but the result of decades of refinement are obvious to me. I am no big Mazda fan (due to reliability issues Ive had) but I must say the Mazda 6 interior PHOTOS look very driver centric (though ive never sat in one).
As another crazy choice, an off lease 5 series Beemer would be a nice highway car I imagine. But Again reliability and out of warranty repair cost scare me.
I am not going to turn this into a HP vs. TQ debate because the reality is HP is a function of TQ over time with is why a lower HP engine with more TQ will be slower. Now gearing does play a very important role as lower gearing will help acceleration but not help elsewhere. Higher gearing will just make you turn high rpms for no point.
The car in question is making a lot more than 70 HP, it makes 200HP with a better transmission. The Sonata weighs 1000 lbs less than a Crown-vic which tips in at 4200 lbs!
So right there is an advantage in weight when climbing a hill. The V8 needs to move 2 tons up a hill, the Sonata can do the same work easier with less weight and a better engine/transmisson combo.
Crown-vic/GMQ are the same really and in fact GMQ is heavier if anything.
Also unless you are driving on flat plains I will call [censored] on getting anything close to high 20's on the highway. It is just not possible with the gearing in the ford tranny. The car that can come close to that is a Corvette because it has a really high 6th gear with a high HP engine. So cruising along under 2000RPM is easy.
We had a '92 Crown Vic, the first year for the Modular engine. The car did not have the dual exhaust package (so was rated at 190 hp), and I believe it had a 2.73:1 open rear. MPG on the highway, sustained, was decent for its size, which was mid-20s. That car took a lot of trips to Michigan and back (Virginia), so it saw a fair share of Pennsylvania hills. I'll bet I could coax upper-20s out of it driving in North Carolina. It was quiet and comfortable. An excellent car.
Having driven that one a LOT, and a few newer ones (2004) more recently, I can't say that I'd prefer one over the efficiency and refinement of a modern FWD sedan (including powertrain and interior space efficiency), but they are nice cars nonetheless.
He was saying that it probably makes 70HP wide open at 2500RPM, which would be the case if it were a manual shift and you floored it in top gear. An automatic would, of course, upshift if you floored it.
I don't believe they've made any with 2.73:1 gears in quite a few years.. My '97 CVPI has 3.27:1, I've seen newer CVPIs with 3.55:1 gears.
Originally Posted By: ekpolk/
Please tell us how many miles you've logged driving an I-4 Camry? No, of course, they're not Corvettes, but they're not meant to be either.
I guess all those mindless morons who've taken Camry sales far beyond the Malibu, the M-6, etc., just all have it wrong. The malibu is a fine car, and I commend GM for producing it. But it's certainly NOT superior to the Camry in any objective sense. I can see where some folks will prefer it, while others will prefer the Camry. This is like arguing about whether chocolate ice cream is superior to strawberry, or vice versa. Please stop trying to tell us that chocolate IS BETTER then strawberry...
I spent a few days with an I-4 Camry as a rental (bare bones version). Compared to the hybrid, it was clearly lighter (the TCH is heavier than a V-6 car), but was also more nose-heavy (much of the TCH's "extra" weight is in the back, where both the 12v and traction batteries are located).
So, would you care to disclose to us your true agenda? And where your disproportionate anti-Camry bias is rooted?
As a professional mechanical engineer, automotive component designer, hobby race driver and general "car guy", all I can say is the camry, dynamically, does nothing well and a fews thing poorly. Such as: like ride tune/handling compromise, rear suspension kick, overly complex gear selector, understeer, intrusive center console. It pushes NO buttons on my "this is a good car" calculator. I do like its exterior styling.
- I did not compare the car to the Corvette, but to weekly rentals I've had this year and last like Mercury GMQ V8, Chev Malibu I4, Buick LeSabre V6. I found the car plenty Fast enough with one onboard.
-Objectively the current malibu platform is carved from stone v. the camry. The previous malibu platform I had driven as a weekly rental was abysmal - so bad i returned it to the rental agency and got something else.
- Having a solid well damped high resonant frequency unitbody is VERY important first step in the making of a good car. The opel epsilon II has this. BUT, I didnt like the Malibu's (electric assist?) power steering feel during quick transition or the high beltline + short side glass low roof - But I wasnt drive out the car by vanilla engineering, when I exit the car I usually thought - not bad for its intended market - good show GM (and overdue!) That said a 1992 Mazda 626 was prob a better car dynamically than either of these current models.
I am comfortable with my choices and i dont need anyone to validate them. If someone is HATING my yaris I will defend it where it is defensible, and concede where it's sloppy ( as in handling dynamics). I am also happy to criticize and talk about the compromises made in the selection of any new car - and there are many of them.
You've mentioned this at least twice now, and I'm befuddled. The 2010 model you said you drove has one of the simplest (and standardized) gear selectors out there.
P
R
N
D
And that's it. You can slide the shifter over from D to go into Sequential mode, and manually + and - the gear range, but it's certainly not required, nor should it be confusing to a competent mechanical engineer, automotive component designer, hobby race car driver, and general car guy.
Are you talking only about CVPI? The MGM and Town Car have the 2.73 gears.
Well I thought the same thing until I bought one and drove it about 40,000 miles. It's obvious you haven't done that.
The gearing in a Ford tranny? LOL At 70 miles an hour the engine is turning about 1600 - 1700 RPMs if you have the 2.73 RAR. Mid to upper 20's MPG is not only very possible it's very doable!
Not only that but I'm not the only one that has had that happen. Read some of the other forums. The EPA rated it as 25 MPG on the freeway. Remember it's not a big V8 but really kind of small for a V8 - 4.6 liters which is somewhere around 280 C.I.
As I've stated before I drive from Southern Ca. to Phoenix several times a year. My last trip - one way was 407 miles, it took 14.1 gallons to refill when I got there. That works out to 28.9 MPG.
One the way home I drove 393 miles and it took 13.9 for 28.3
This is driving on Interstate 10 where there are a couple of long hills in the Palm Springs and Indio area.
I've made two trips from Southern Ca. to Seattle Washington. This is with 4 large adults and a very full trunk, traveling in the wintertime. The weather in northern Ca. and Oregon is usually not the best (cold and rainy). I've averaged just under 25 MPG on one trip just over 25 on the other. This is 1200 miles each way. I have it all documented - receipts for gasoline and my mileage.
The one I saw (which was in an Avalon, I believe) had confusing markings on it which would lead you to believe that the neutral position was where + actually is--when neutral is really to the right of that. I don't know if the Camry uses that same design but I do see a problem with it.
It looked a bit like this:
P
R
+N
D
Is a Legacy too big?
A 2011 2.5i Ltd. has an MSRP of $25,295 and gets 31 mpg highway with the CVT.
-Dennis
The Camry uses the same design, and it's awfully straight-forward to me. My wife, mother, and mother-in-law have all been able to figure it out without instruction. It's pretty much the same gate that Toyota uses on all of their 6AT cars.
Park, Reverse, Neutral, and Drive. They're all in a line. If you want Sequential, you pull it left and tap forward for + and rearward for -. It doesn't get a whole lot simpler than that (at least to me).
