I figured I'd update this; maybe some one will take interest and hand me a silver bullet
Regardless of whether the car is cold or fully warmed up, it will usually vibrate moderately - think of an outboard two stroke type of unbalanced something vibration, but with out the two stroke noise, and the motor runs seemingly fine, though 1/50 starts from stop will hesitate a little - when I come to a full stop. It will not vibrate at 1/2 mph, but only when fully stopped or inching forward with the brakes applied.
Something new that was only rarely noticeable before, but is becoming much more prevalent is a vibrating rattle that does NOT sound like metal on metal. It happens whether the brakes are applied or not (e.g., if I'm on a hill with the car in D, not moving, and no brakes applied.) If I press down very firmly on the brakes the vibration will subside. The booster, master cylinder and pedal to booster pivot/mount are all seemingly solid, so I think it's something unrelated to the vibration vibrating against the firewall; something that stops rattling when the firewall is slightly flexed when I stomp on the brake pedal (just a guess until I investigate further.
I noticed that while accelerating (hard or moderate, even) the vibration isn't that bad in 2nd and 3rd gear (auto tranny), but when it's an uphill jont, it'll vibrate pretty badly.
Hopefully some one can help. FWIW, I still do hear some clicking - one, not rapidly like a failed CV shaft would produce - while maneuvering at slow speeds (e.g., making a three-point turn.) I have a feeling that this noise has more to do with worn bushings some where rather than what's causing my vibration, but I figured I'd throw it out there.
