gathermewool
Site Donor 2025
What:
Higher frequency vibration that shakes the car. In my mind, a low frequency vibration would be if a cylinder were missing or if the car were running roughly. This is not that.
When:
1. Fully stopped, regardless of whether my foot is on the brake or not.
2. Acceleration at greater than granny-style or accelerating uphill between 2-3k RPM. I've noticed this both in second and third gear.
Recent Maintenance:
1. Both CV shafts replaced with new within the last 3 months. Replaced the driver-side CV shaft again last month thinking that was the issue. No change.
2 Plugs changed out from NGK plat to NGK Cu along with new wires 6 months before the vibration started occuring. I pulled them last week and they looked perfect, no fouling and the gap was spot on at .04
3. Fuel pump replaced in the freezing freaking cold last night in my parking lot. The strainer is new and the filter was replaced as well. The death rattle coming from the pump is gone, but the vibration remains.
4. Transmission fluid drained and filled a few times in the past 40k. The latest was with 6 qts of Amsoil ATF 1.5 years ago. Fluid looks great, and is at proper level.
What I've noticed:
1. Transmission mount and passenger side motor mount both look good - probably not the original. The driver-side is old-looking and dirty, but seems sound - no cracks or bulging, and it feels as pliable as the newer looking passenger-side mount.
2. The vibration issue isn't consistent. It SEEMS that it's MUCH better after driving around for a while, when the transmission has come up to temp. My commute is 5 miles to work and, while the coolant just gets up to temp, I'm guessing the transmission hasn't. The bad when I leave for work and slightly better, but still very noticeable when i get to work. When I drive around town running errands it seems to subside even more.
3. My freaking front right caliper is leaking fluid past the piston Life time warranty on that one, though!
What I've found on the interwebs:
1. Most people who had something similar had their mounts, plugs, wires and coil pack replaced, none of which fixed the issue.
2. No one come back when they've either given up or solved the problem! Every one asks for a solution, and while knowing what does NOT work is good, knowing how you fixed it back n 2007 is probably better.
I promise to update this if I figure out the issue.
When:
Recent Maintenance:
What I've noticed:
