Subaru OE [cut-open]
Originally Posted By: KCJeep
Interesting pics Soob, thanks for posting. That must be a very application specific filter, as that orange can looks to have quite a bit more pleats than most and internally is awful similar to the OEM. Maybe that is due to it being so short.
That is correct. The FRAM PH9715 is only referenced for 2005 - 20012 Subaru 2.0 and 2.5 EJ2XX engines and some Saab 9-2x models using the same engine. Also "ExtraGuard" isn't stamped anywhere on the filter. It just says FRAM PH9715.
FRAM PH9715
Product Type Full-Flow Lube Spin-on
Anti-Drain Valve YES
Gasket I.D. 2.21"
Gasket O.D. 2.48"
Gasket Thickness .21"
Gasket Usage Base
Product Height 2.63"
Product I.D. 20mmx1.5mm Th'd
Product O.D. 2.69"
Relief Valve Setting PSI 16-28
