- Joined
- Mar 15, 2026
- Messages
- 49
I was bored today, and thought I would put together a Subaru maintenance strategy using Subaru’s guide and info learned here. Using Top Tier gas and only BITOG endorsed fluids…
Subaru Maintenance Best Practices:
Initial Break In Period
- 1,000 mile and 3,000 mile oil changes
- 5,000 mile MT tranny and differentials
4,000 miles (or 6 months while under warranty)
- Oil and oil filter
- Every Other Oil Change*
* Techron Complete System Fuel Cleaner before OC
* Rotate Tires in rearward cross pattern
12,000 miles (2 years)
- HVAC filter
30,000 miles (2.5 years)
- Air filter (don’t do early, efficiency goes up as loaded)
- Clean MAF sensor
- MT/CVT Transmission drain and fill
- Differentials drain and fill (probably conservative)
- Brake/Clutch fluid*
* Only do some bleeding for every pad replacement.
60,000 miles (5 years)
- Spark Plugs
- PCV valve
- Clean Throttle Body
72,000 miles (6 years)
- Fuel filter*
* not happening… in fuel tank
First 137,500 miles or 11 years, then 75K / 6 years
- Engine coolant
As Needed
- Wipers
- Car Battery
- Tires
- Brake pads and discs*
* Bleed and fill some brake/clutch fluid every pad replacement
- AC charge
- walnut shell blasting for direct injection engines
Questions:
- I don’t drive that many miles, so the minimum time duration would always come first, however I plan to follow only miles (except I am doing oil changes every 6 months while under warranty). Any situations only going on miles and not time is truly detrimental?
- Do you really have to follow the manual’s specific brake flush recommendation vs just bleed and fill some at every caliper pad replacement? (this feels a lot more practical)
- Anyone really finding Subaru fuel filter replacements necessary (annoying they are in the fuel tanks).
- Spark Plugs at only 60K miles is annoying, but I understand they spark twice during the cycle (wasted spark ignition system).
- Any other thoughts, suggestions, or criticisms to this strategy?
- HVAC filter
- Clean MAF sensor
- Spark Plugs
- PCV valve
- Fuel filter*
- Engine coolant
As Needed
- Wipers
- Car Battery
- Tires
- AC charge
Questions:
