PhilloBeddow
Thread starter
2014 Subaru legacy FB25 6MT, 95000 miles, owned since new.
Short block replaced under warranty at 50000 miles because of excessive oil consumption. Spark plugs replaced at same time just because. Iridiums.
Oil consumption is … ok I guess but still there. My annual mileage about halved when I retired to about 6-7k / year and I’m on the severe OCI schedule as I do a lot of in-town driving.
Currently close to the end of my first 0W-20 VRP OCI and oil consumption seems somewhat reduced but hard to quantify. I’ll be staying with VRP for the next few OCIs. I’m aware 5W-30 will probably reduce oil consumption but I want a baseline for comparison, hence Subaru recommended 0W-20 for the first few OCIs.
Gas is usually Costco Top Tier and the 2014 legacy is port injected (MY2018 was when the Legacy went GDI I believe) so I don’t anticipate valve carbon build up being a problem.
That’s the background. Here’s my question -
Is a piston soak feasible for a flat 4 engine ? Notwithstanding the difficulty of getting to the spark plugs how would you soak the rings evenly?
The only way I can think to do that is to lay an old mattress down and flip the car on its side. I don’t want to do that because my wife will want the extra garage space and then I’ll have to park like that all the time.
Would adding Berrymans B-12 to the gas tank help if I’m already using Top Tier?
I want to minimize the oil consumption as best I can going forwards but I think I might already be past the point of diminishing returns and I don’t want to be an idiot about it.
What say you all?
What say you all?
