In the saga of the Chevy Blazer I’m working on, I installed a new radiator - only problem was that the drain plug was a Japanese-style winged one. To loosen it, I had to use a pair of needle-nose pliers to bust it loose. That meant I had to undo the lower oil cooler line to get access to it.
I thought I tightened it back - nope. It was only on finger-tight. There was a puddle of oil, lost about 1/2 quart. We shut down the engine and tightened the line up. Restarted it, no weird sounds.
I don’t know how the oil system schematics on this - the engine was running for 15 seconds before I realized my mistake. Should I keep an ear out for any weird sounds or do an UOA of the old fill?
