Revival of the '94 Escort...
Staten Island, NY
Well *clears throat*
Time to stop lurking and start bringing OC back
Just shoved into the backyard is a friends '94 Escort (1.9 CVH Automatic)
They call it an LX, which stands for Luxury Xperience?
Manual locks/windows, strangle yourself passive restraints, yet power mirrors, frigid A/C, and a mostly functional heated rear window
Got a whole 42,000 miles under it's belt
It's shall we say, aesthetically challenged?
In that Solo cup 90's teal
#90sclearcoatproblems
So the story goes like this
Last December, me and him put a heater core in it, so it'd be a useable winter transport
January rolls in, and he takes it on a road trip to Central PA, and slips on a patch of black ice
Caddy corners a tree stump
Luckily, wasn't hurt, and no airbags were harmed
Local shops told him $1,500 minimum, I say junk it there and Amtrak back
Turns out he had the top line AAA membership, which covers 300 miles of towing
165 of those miles later, it comes back to NYC and sits for 6 months on the corner of my block
After it'd damaged enough property values, money and time were allocated to making it viable again
He cracked the control arm at the weld, which bent the axle and sent it punching a hole in the back of the oil pan
Swapped the control arm (which is a pain because the oil pan blocks the bolt)
Dad decided to lend a hand in removing the twisted sway bar link that'd only spin
In doing so he busted up his finger pretty bad, so work halts for a trip to the ER
Sway bar links...
Rolled it down the street and into the backyard to assess if it was possible to make it a whole car again
Dropped the exhaust (the accident conveniently snapped the converter to flex pipe bolts)
Manifold to converter nuts were a chore, but Kroil and a MAPP gas torch made it doable
Got the oil pan off, saw how there was no oil left, and all the metal chunks
Inner CV axle came apart when the axle bent, and stoved right into the back of the oil pan
Tried to remove the drain plug, it was cross threaded and stripped to a mirror finish
...I never liked that oil pan anyways
Cleaned the oil pickup with some brake clean, because why not?
Until the hose came off and a spritz of brake clean got me in the eye (note to self, it burns)
WEAR YOUR SAFETY SQUINTS AT ALL TIMES
Not just when you think you need them, ALL THE TIME
A few days of rest later, Got the new pan all clean and dressed
New gasket, and some well placed Ultra Black, because there will be no leaks!
Bolt it all together, and torque in sequence to spec (Thanks AllData)
Spin a fresh 400S on (Because if it's not genuine, I don't want it
Real BITOG'ers don't tolerate overtightened, non gasket oiled, ADBV malfunctioning, no name jobber filters
4 quarts of the good stuff go in (Walmart SuperTech 5w30)
I pull the coil plug and fuel pump fuse
Crank it over until the oil pressure light went out
Checked for leaks
Repeated this 5 times or so
Plugged everything in
Crossed my fingers, turned the key
And she fired first try, like nothing ever happened
I could hear all 88 angry horsepower resonating off the walls through the Genuine Ford Racing Manifold only exhaust system
No flickering oil lights, no rattley top end, no deep bottom end knock
It sounded just like I remember it did (A/C still works too!)
Guess the owner wasn't lying when he said he shut it off the second he finished crashing
I let it warm up, so the belt could wear the rust off the pulleys, and saw that the transmission still engaged
The verdict was in, this car's got a bright future
I promoted it to slightly above station car status
I received an axle and sway bar links today
So it's gonna go back together hopefully this weekend
Gotta find some hardware and a gasket to bolt the two studless exhaust flanges back together, and get it rolling under it's own power again
Now I assume you all came for those sweet internal engine pictures?
And you shall receive
It actually looks dirtier in the pictures then in real light
Those puddles in the rockers and drips off the rod caps look black, but the oil was clean?
Then again, that oil pan with hole was sitting for 6 months exposed to air and moisture and salt
One more OCI, and I suspect oil will be the least of the cars problems
That oil pan was a PITA to find, they don't make them new anymore
Luckily, found the good used one pictured on eBay for $50~
They even painted it for me, fine people of an online Salvage Yard in Ohio
Hopefully, soon the saga of the '94 Escort will conclude...
And it will return to it's life of running to the local store, running up and down I-95, sitting in traffic on the B.Q.E, all while making you feel like you're living within your means, and getting very respectable fuel economy
Seriously, this thing gets like 25 on a bad day, 30 MPG without really trying, odd for an automatic...
Great work here
Very good write up and pics too. Well done indeed. I had a 89 Ford Probe that was given to me by my mom. It was a LX version too. I wondered what that meant too. A very good car in fact. Basically a Mazda motor and transmission in it. I saw one just yesterday and I was shocked to see one.
Aargh-memories of my poor misspent youth, I personally had an '83 & an '85 1/2, my Mom had an '81 Lynx & a '94 Tracer wagon. Made me appreciate Toyota small cars & even a Cavalier or two...
You must live in Whitestone as that's the only neighborhood I know of where you can park a car for days on end without having to move it.
You did say NYC.
EXCELLENT write up.
Also, what killed my Mom's '94 1.9 Tracer was an intake seat dropping out of the head & imbedding into the piston-if I was putting $ into one, I would pull the head & stake those seats in-hers died with 90K on it. Love those Ford aluminum heads!
IIRC, the OP lives across the GG (ethnic slur gangplank or Veranzano Bridge) in Staten Italy (which always made me laugh).
I enjoyed the write-up but I agree you have to watch that CVH for dropped valve seats (common issue).....if you correct that issue the car should soldier on indefinitely.
Good thought on the strategically placed black RTV. I had a 93 and replaced the oil pan gasket twice after the dealer did it once and still had ooze. The dealer mechanic simply said, "Escorts and Tempos leak." Both used that type of cast aluminum oil pan. My guess is that it will not "flex" and form as good a fit to the bottom of the engine as a stamped steel pan would. Hopefully, the addition of the sealant will prevent that. If you ever notice substantial vibration while stopped at lights it is most likely a messed up harmonic balancer. Apparently, those separate sometimes.
Also, I like Poland Spring water. I buy a lot of it on every trip to NYC.
My sister had either an 89 or a 90 Escort,bought it brand new back then. She said it was one of the best cars she's ever had.
With the 1991 model year the Escort became a sort of Ford/Mazda hybrid. The engine was Ford (1.9L), transmission (at least the automatic) and suspension was Mazda. Interesting combination that resulted in a reliable, but boring, experience. The GT version had a Mazda DOHC 1.8L engine which gave it a little oomph. The Mercury Tracer was its corporate twin.
My girlfriend back in the day had a 2 door 94 Escort LX wtih the 1.9L 5spd. That litte car ran great after a new cap,rotor,plugs and wires when I first started dating her. She ended up trading it in on a brand new 1998 Chevy Caviler at a dealership while I was at work without my knowledge. I asked her how much they offered her & she said 500 bucks off her new car. I called them & offered them 500 cash & they said -- no. I missed that little car when it was gone & thanks for the post & refreshing some memories.
Wow. If my GF traded in her car without asking me if I wanted to buy it, she probably wouldn't be my GF anymore...J/K...sorta..
Something is off here. The 1.9L Ford engine has distributorless ignition. It had a single coil block and spark plug wires, but no distributor and thus no cap. That car must have had the optional MAZDA 1.8L DOHC engine, which did have a distributor. It was 127hp rather than the 88hp in the Ford 1.9L.
Well, it's coming along
Axle and exhaust are back together
Only problem is, when I pulled the remnants of the inner CV joint, I was not prepared for fluid
Does this automatic have a separate fill and drain for the differential?
It's a F-4EAT automatic
Anyone ever service one before?
