Well at this point I'm fairly certain I've bent valves. I redid the timing perfectly. Much better than before (cam locking bar goes in perfectly with crank at TDC). I put the spark plugs back in cranked it over and still zero compression at the compression tester gauge. I cranked the engine for at least a minute in total so I would think that would have cleared the flooding if there was any, but maybe there's not enough compression to push the fluids out the exhaust? The engine still cranks fast, and there is an audible whistling in the engine bay as it cranks, and if I put my head near the back of the engine I can feel pressure on my face so I think compression is leaking out somewhere it's not supposed to.. Should I keep trying to deflood or just start pulling the heads..?
