Freeze off. I found out about this stuff when I worked for a guy building race cars. Advance Auto Parts has it. It bubbles and wicks its way into threads. My cousins 350z had stuck bolts until I sprayed it with Freeze Off.I would appreciate any suggestions for removing a stuck O2 sensor on my 87 F150. I have tried everything I know of and am affraid of it snapping off.
Yes and soaked several time with PB Blaster.@Lubener, have you tried a torch?
so you have to break off the top end of it (it's easy) to make it fit.
Heat the area chery red with acetylene torch. Use good leverage to then break it free.I would appreciate any suggestions for removing a stuck O2 sensor on my 87 F150. I have tried everything I know of and am affraid of it snapping off. I have tried heat and PB Blaster.
