Stuck O2 sensor
I would appreciate any suggestions for removing a stuck O2 sensor on my 87 F150. I have tried everything I know of and am affraid of it snapping off. I have tried heat and PB Blaster.
Freeze off. I found out about this stuff when I worked for a guy building race cars. Advance Auto Parts has it. It bubbles and wicks its way into threads. My cousins 350z had stuck bolts until I sprayed it with Freeze Off.
Spray on whatever break free you have then get it hot by running the engine. Make sure you use a good socket like a Kent-Moore brand or other USA made one. 1/2" drive preferrably. I might even buzz it lightly both directions with an impact tool to loosen the corrosion.
I've had to resort to this item a couple times:
https://www.amazon.com/dp/B08KHWHS4G?ref=ppx_yo2ov_dt_b_fed_asin_title
It's a larger version of those special sockets you use to remove rounded-off lugnuts. Be aware the oxygen sensor is too tall to fit inside the socket, so you have to break off the top end of it (it's easy) to make it fit. You might also have to use a tap to restore the threads in the manifold if they got boogered up for some reason.
Cut the wire off, then use one of those new fangled inductive heaters so as to heat up the works, then put a box end wrench on it and give that a good whack with a hammer? Alternating heat and quenching with a penetrating fluid like PB Blaster might do the trick.
I keep a 3lb (maybe 4lb) dead blow hammer around for persuading bolts. A good rap on a wrench often does the trick when I can't use a breaker bar.
I have an appointment with a decades old, locally owned exhaust/muffler shop for a cold start exhaust leak check/repair on my Chevy 5.3. There’s a reason why me and most Indy shops don’t do exhaust system repairs! 🤬
Heat the area chery red with acetylene torch. Use good leverage to then break it free.
Other then that, a good exhaust shop will get that sucker off in 10 min or so and send you down the road. Shouldn't cost no more then $50-75 bucks.
Be willing to break it - and then put a good quality impact socket on it.
Heat is your friend. So is an impact.
If you need to preserve it, then pony up and get a good socket for it. My shop neighbor has borrowed this a couple of times. 22mm flare nut crowfoot wrench. Strong enough not to flex under load, and with great grip, it removes stuck O2 sensors where you can’t get an impact on it.
https://www.tekton.com/3-8-inch-drive-x-22-mm-deep-6-point-flare-nut-crowfoot-wrench-wcf16222
I had that situation years ago on my 98 Chevy K3500. I could not get it out for anything, even with heat and a breaker bar. I ended up taking it to an exhaust shop. They ruined the threads of the bung and had to weld in a new one.
Get the bung cherry hot & pour water on it.
The O2 is stainless & the bung may be a lower grade of stainless if it's in the exhaust not the manifold....Could be stuck for good if it's stainless on stainless.
Can you just punch a new hole adjacent to the original & weld in a new bung? IIRC Ford liked to run AIR tubes down to the converter making pipe removal a bear
