Stuck ATF drain plug
TX south plains
Was going to do a drain and refill with a pan drop and filter change on my 1994 Jag XJS. Didn't get very far though. The 5mm allen hex drain bolt wouldn't budge at all. Any hints on how to get it out? I pulled as hard as I dared without stripping the allen key out (and I hope I stopped in time).
TIA
Spray something like PB Blaster onto the bolt, wait a few minutes then try again. Not sure what kind of hex tool you use but you could attach a long pipe to the hex key to give you extra leverage. Good luck.
A while back I helped my friend change the transmission fluid/filter on his BMW and the fill/check plug was super tight. I always remove the fill plug first just in case the I can't get the drain plug off. Sprayed some PB Blaster onto the bolt and not sure if its placebo but it worked. Oddly the drain plug didn't take much effort to loosen.
Just drop the pan. Doesn't it have a filter that needs to be changed anyways? They don't usually put drain plugs on new vehicles these days anyways. People mistake them for oil drain plugs and drain the wrong fluid out.
ALL 7 of the new vehicles I've driven lately had transmission drain plugs (pan not torque converter)
So I'd have to say your comment is incorrect.
The last ATF drain plug I saw was on a 1959 car, not counting aftermarket add-ons.
They are making a comeback which is good to see since the drainplug was always a good idea. It'd be nice if the fuel tank drains came back as well.
First, have a new drain plug on hand. After you have that take a dremel with a cut off wheel and make a slot. Then take a small chisel and hammer and knock it loose.
Think this may be the route I go with since I do have a new gasket and filter to go in.
Don't think I'd actually do this but saw/read somewhere there is a 'freeze it' bolt loosner spray on the market now. Would that be a conceivable option or just asking for trouble. I don't have a replacement on hand so I'm not going to risk it. Next time I order parts for her I'll likely see if I can get one to have on hand.
Thanks for all the replies.
My 2008 xB has an ATF drain plug. So I have been doing drain/fills every 15K or so. It is half an oil change of work, so why not!
