After posting a couple questions about what oil to run in my 95 Nissan MT truck,I decided on the Amsoil GL4 mt oil. I went into the garage and got everything ready to drain the tranny and the check/fill plug will not budge! I tried the ratchet first then the pull handle and finally the impact wrench all to no avail! I shot some PB blaster on both plugs but still can't get them to budge! I have focused on the check/fill plug since I will need it out to fill it up if I ever get it off. I'm assuming the drain plug is going to be a bear also. Do you guys have any suggestions? Thanks
