Struts? Easy. Headlight not so much.
California
I have a 2003 Hyundai Elantra that I inherited when my dad passed. He bought it new. I recently bought tires from the Boys of Pep, and they pointed out to me that the struts were original, and, since the car has about 120,000 miles on it, should be replaced. I got the Monroe Quick-Strut assemblies that come with new springs. I watched a YouTube video from 1A Auto Parts that showed how to do it, and it actually wasn't too hard. It requires more muscle than skill, and my car rides a lot better now. I need to do the rears, too, but that doesn't look quite so easy.
Then I discovered that the driver's side headlight was out. I replaced the passenger-side headlight bulb a while back, and it wasn't a big deal. However, to do the driver's side, you have to pull the engine. OK, not quite, but there's one of those plastic covers that has to be removed, which for some reason is also bolted to the airbox, and you have to pull the battery out. I had forgotten about the spring clip that holds the bulb. When you touch it, it shoots out into the engine compartment at approximately 300 miles per hour. I think the hardest part of the whole deal was figuring out how to put that stupid clip back in. Anyway, they managed to take a job that, on many cars, requires no tools, and make it a real pain.
Originally Posted By: rooflessVW
At least you didn't have to remove the bumper cover and headlight assembly.
yup like 7gen Malibu's 08-12. Pain in the but at first not to bad once u have done it a few times.
The cherokee you have to remove a wheel.. and pull the fenderwell(plastic) totally out.
earlier models (2014/15) had an access panel in there.
Mine is going to a shop and every bulb is getting changed at once. Hopefully its gone before it ever needs it again.
The "hinge" that holds the clip on my Rav4 has broken due to, I guess, metal fatigue. Need to replace the entire headlight unit ($$) to fix it properly. I just have the rubber grommet holding the lamps in place.
Need to have very long, very skinny, very strong fingers to change headlights on these cars.
My Jeep is one of the easiest to change a headlight bulb on. One bolt and the whole housing comes out. A minute or so later you are done.
Have to remove the bumper and headlight assembly on my Cadillac as well. I replaced every single bulb with whatever advertised the longest life while I was in there..
Some of the Mazda I think 3s are like that when they have HIDs. Had a service writer bring one in on a Saturday after I confirmed it was HID and the OEM bulb was in the $250 range and the tech working that day said he wanted 2 hours minimum and to have the car stay the rest of the day. The writer told the customer it would only be $25 and should take 10 minutes even after us telling him otherwise. Customer tried to yell at me about it which they walked out with the instructions cursing Mazda instead.
