headlight install mistake ... 5 years ago
Akron, Ohio
Not meaning to fire up the "Aftermarket LED headlights are bad" issue, but I installed Sylvania LED H7 bulbs in my 17 Camaro with great results. Driving home the other night, I noticed a 'dead spot' in the light pattern from the left headlight. Once home, the lights hitting the back wall of the garage confirmed the dead spot was from the left headlight.
I was too tired to deal with it then, so I wated until this morning to check. Originally, I thought one of the LED chips might have gone out, so I opened the hood to pull the bulb. After snaking my hand and forearm through a maze of obstacles, I felt the first spring clip holding the bulb in place and released it. To my surprise, the bulb then popped out into my hand - with the 2nd clip still in place. I pulled the bulb out and was confused for a second. The clip ring that is (supposed to be) attached to the bulb was missing. A quic look with the flashlight confirmed it was still locked in by the 2nd clip.
Thinking the bulb was supposed to be onepiece, I immediately thought of Super Glue or epoxy to put it back. I decided against that because the bulbs should still be under warranty (5-year defect). So I grabbed the box the bulbs came in to take it back to the store (amazingly I still had the box). As I opened the box to put the bulb in, the installation instructions fell out. Figuring WTH, I opened the instructions.
One of the FIRST things they say to do is to REMOVE THE CLIP RING FROM THE BULB and install it in the headlight housing!!! THEN they say to install the bulb into the clip ring, using the alignment pins and twist the bulb inside the ring until the wire is pointing down and the bulb will then BE LOCKED IN PLACE!!!!
Guess what I never did?
Moral of the story? Keep the box until the warranty expires and at least LOOK OVER the instructions if doing something you haven't done before.
Sharp!
An honest mistake. I too would've done that because i'd've just popped them in like normal bulbs and wouldn't have thought to do any of that cause I never read the manual either.
It's always the littlest of things which always seem to get in ones way and it become infuriating when the accumulate via the butterfly effect.
I often don't read the instructions. Beginning to though more and more,
Once when we got a new computer I decided to just plug it in, turn it on and follow the prompts. It worked fine. I was feeling really good about this helpful modern technology.
Then I read the manual. The first instruction was DO NOT turn it on and follow the prompts.
Thanks to all for the comments on the car. In a former life, I was a detailer (WAAAYYY back in the late 80's), but I took a different career path. I still kept up with detailing and was (I thought) really good. Just shy of a year ago, I started learning from Yvan Lecroix / DIY Detail and my skills shot through the roof.
As a result, my car (2017 w/86,000 miles, and my wife's car (2013 w/95,000 miles) look better than showroom ... as do anyone's car who trust me to "play" with them.
Do you have a digital rear view “mirror” ? … I rented those - drove great but the blind spots were tough …
It has a very large display for the back-up camara that also has a very wide point of view. Helps A LOT.
  • Like
Reactions: 4wd
