I'm trying to change the filter on the Saturn Ion. It's got those fittings where you squeeze in the tabs to release it, but been I been at it an hour with no luck. Twisting, pressing in and prying out. Don't want to risk breaking the plastic fitting. Maybe rust on the filter has expanded so it's stuck? Should I spray some lube on it? Cut off the nipple flush with the filter and deal with the broken end stuck in the fitting more easily?
