I have a stroker engine professionally built by HESCO. The slight preponderance of info on this sight points to 5w40 synthetic for the regular 4.0L. What's your advice on this stroked straight six?
I've been working in Iraq since December 2003. I go home for good Jan 1. Army Contractor.quote:
Originally posted by Santo Fontana:
Isnt there quench area issues with hybrids like that? It sounds like this guy has an aftermarket stroker kit.
Dark Horse I notice you are in Iraq! What are the driving conditions this vehicle will be subjected to? Can you tell us a little more about your setup?
Mobil 1 Delvac has a 10w30 as well - should I go with that or their 15w40?quote:
I would run delo or delvac 15w40 and change it frequently. With a preoiler you dont have to worry about startup flow too much, and under those conditions you dont want to go for extended drains, even with a bypass, IMO.
Found it here on the Mobil 1 website: http://www.mobil.com/USA-English/Lubes/PDS/NAUSE2CVLMOMobil_Delvac_1300_Super.asp#ApplicationsTitlequote:
Those diesel oils are also fleet oils, and are ok to use in gas engines. Some say the high level of additives could hurt your cat, but I doubt you will be running one (?). I run delo 15w40 in my completely stock chevy van. They are thick, stable, keep engines clean, and have strong add packs. Best of all they are cheap. I have never heard of M1 Delvac 10w30, where can you get it?
I like very long road trips and frequent offroading - probably leaning toward the 40 weight now.quote:
Originally posted by Gary Allan:
The Delvac 10w-30 exists ..but only (allegedly) in bulk ..or maybe 55 gallon drums. Other refiners have 10w-30 HDEO available in quarts or 5 gallon pails.
..but the 4.0/4.2 appears to prefer a 40 weight in service applications where oil temp is allowed to peak/stabalize. That is, if you're a short trip type ..then a 30 weight appears to do well in our little community here. This isn't a solid given ..just the majority of AMC/DC inline 6 engines show lower Fe numbers in the UOA section that infers that higher (effective) viscosity has a definite impact.
In any situation other then a 4 season climate in a short trip service (10 miles +/-) I'd have a 40 weight in there. If the climate had a severe cold component to it ..but had a fairly long trip length ..I'd use a synth 40 weight.
Did you opt for the aluminum head from Hesco? That would be an interesting addition to a stroker.
I'm not sure what you're asking about the high flow cooolant bypass. The engine will be setup the same as stock unless I learn a better way (fill me in).quote:
With your sevice there is no doubt in my mind that a 40 weight would be recommended. The only question you have to answer is the service length and whether to use a dino or synth based on the conditions. In a dusty enviroment like you're in ..surely a synth would be a waste with the freuent changes that you would probably need. In your colder climates it would probably prove beneficial.
Do you run the standard high flow coolant bypass setup on your engine (continuously through the heater core)? This is what allows the contemporary 4.0 to warm in a very short period of time ..faster than some aluminum head engines that I own and have owned. I'm just curious since Hesco is pretty much down with the inline AMC/DC 6 ..more than any one source that I've seen. They offer highflow water pumps and whatnot ...and they manufactured the entire inventory of MOPAR roller rockers for the 4.0/2.5.
My rig is an expedition rig - spares, tools, armor, cage, bumpers, winch. 30 pounds won't begin to make a difference. Especially with greater longevity from their regular ported head and for me it's not worth the weight savings or minor performance gains to go with their very impressive aluminum head. And the extra 2 grand.quote:
Originally posted by 99:
Hesco makes some real nice 6cyl parts. That aluminum head is a work of art. Too bad most 4.0s will never be able to take full advantage of the flow it offers. I'd run the aluminum head for the weight savings alone....the factory iron head is a boat anchor.
1. Yes, they are installing a high flow water pump. Will this make it take much longer to heat up to temp?quote:
The 4.0 allegedly has a high flow coolant bypass. That is, a good bit of your coolant flow isn't seeing the rad. They attempt to compensate with a decent size rad for the displacement. This is what allows a cast iron engine to achieve low emissions status in a very short time. My 4.0 warms up in an incredibly short distance ..even in winter...even compared to my 3.0 aluminum head Mitsubishi. Choking, or restricting, this continuous high flow bypass flow is one technique for increasing the cooling capacity for the engine. This can also be accomplished by using a high flow water pump ..making the % of flow in continuous bypass a non-factor.
And is the Mobil 1 Delvac 15w40 a synthetic? Where can I buy it? Delvac 1 is a 5w-40. It has the same spec's as M1 Truck & SUV and is available world wide under one or the other label (or both). The 15w-40 is a dino, Delvac 1300. WallMart usually has both.
Also, running an aluminum 2 row radiator - standard thermostat is 195 degree, should I run a 180 degree? I have an oil cooler.Also, running an aluminum 2 row radiator - standard thermostat is 195 degree, should I run a 180 degree? I have an oil cooler.
The 195 is your best bet. Sounds like your rad is up to the task. What type of oil cooler do you use? A mopar heat exchanger (Modine®) ..or a rad type?
