- Joined
- Jul 10, 2022
- Messages
- 6,055
Did not know that....I figured that a shop has an easy time getting broken bolts out....the only ones I've tried were small, and, I found that I could even drill a hole right through the middle, but could still not get the complete bolt out, what's left still frozen in the threadsThere are countless ways to extract broken stuff. It all depends on the application, position and the materials. The best thing one can do as a pre task, task, is to generously soak in a penetrating oil. My favorite is ATF and Acetone mix.
It is rare, that if a bolt head has broken off, a drill in extractor will get it
quick question--what would you do if the other side is the exact same, but, not broken yet? Technically the caliper doesn't need to come off for pads...but it does for the rotor (Lexus LS430). So for now, the bolt can be left alone for years....
